Rob Bice Posted September 5, 2010 Share Posted September 5, 2010 I am working on rebuilding a wrecked 1990 LS400 that was wrecked in the front LH corner. The problem that I am having is the relays behind the headlight on that side were distroyed. The vehicle will not run, and I am trying to figure if this has anything to do with it. The inst cluster is also missing, and will need to be replaced. Anyone have any idea what these relays do or are? Thank You, Rob Quote Link to comment Share on other sites More sharing options...
VBdenny Posted September 6, 2010 Share Posted September 6, 2010 I have seen these parts in jumkyards. I imagine the relays are pretty much the same as on a Toyota. Quote Link to comment Share on other sites More sharing options...
fsuguy Posted September 8, 2010 Share Posted September 8, 2010 I am working on rebuilding a wrecked 1990 LS400 that was wrecked in the front LH corner. The problem that I am having is the relays behind the headlight on that side were distroyed. The vehicle will not run, and I am trying to figure if this has anything to do with it. The inst cluster is also missing, and will need to be replaced. Anyone have any idea what these relays do or are? Thank You, Rob If the '90 is similar to the '92, then your relays on the left (behind the battery) include the Electronic Fuel Injection (EFI), cooling fan relays (x2), seat heater relays, cigarette lighter relay, headlights, horn etc. Sorry I cannot be more detailed - this is just from memory from working on my '92. HTH Mike Quote Link to comment Share on other sites More sharing options...
