The dealer said due to "faulty amplifier" parts $689. I don't have this kind of money now, any other options?
Thanks!
Thanks!
I may have an amp, PM or EM me.
Thanks!
Afanti, If your still around here, What year GX470 ?
Thanks!
Yes, I am here. Thanks!
My GX470 is 2004.
Thanks!
My GX470 is 2004.
Thanks!
My GX470 is 2004.
Thanks but where can I have it installed?
Thanks!
My GX470 is 2004.
Easy emough to DIY, Or have a repair shop do the install. I'll send install instructions.
Thanks!
My GX470 is 2004.
How much for your amp? Thanks!!
Thanks!
My GX470 is 2004.
I also have Mark Levinson stereo amp problem. I have a 2003 GX470 with a mark Levinson amplifier that has died. Any ideas where another amplifier could be obtained?
Yes, The 2003 to 2004 gx470 amp is # 86280-0w140 EM , PM me or leave youe email. Welcome to the club cheers.gif
  • Like 1
  • 11 months later...
do you still have a functionnal amp? or even better if its been refurbished- (to fix the inhenrent problem with the amps?)
i would need one for my 2004 gx470 mark levinson system
tks
Matt
cherryhill@acanac.net
  • 3 weeks later...
I'm looking for amplifier for my 2004 GX470 as well. It has been working on and off for about a year. Serious scratchy noises in the driver door when it is working. ???
  • 2 years later...
Hi Although this particular topic is about 3-4 years now, i am recently experiencing the same and would really like to purchase an Amp and do an outright replacement.
Any ideas?
  • 2 months later...
We had this happen during a long road trip. For some reason, the volume knob stopped working, volume was fixed at 30 without any way to adjust it. Steering volume controls also made no difference. I turned the car off & on hoping to reset the system and as a result we had no sound at all. I suppose volume was stuck at 0, but there was no way to check.
The solution was to remove the two fuses for the radio and amplifier, then replace them. I suppose disconnecting the battery would have worked, but that seemed extreme. After the fuses were re-seated, everything was back to normal.
I hope that helps someone.
  • 2 years later...
Hi, I know this is a old post but I'm in need of a amplifier for my 2004 GX470.  I'm having a hard time finding one even on Ebay.  Any suggestions?  Mine is 86280-0W140
