herkitkat2222@verizon.net Posted August 13, 2010 Share Posted August 13, 2010 my ABS light is on. The brakes work fine and I think the sensors just need cleaning. Does anyone know where the sensors are located? Quote Link to comment Share on other sites More sharing options...
gbhrps Posted August 15, 2010 Share Posted August 15, 2010 Once you pull each wheel from the car, you'll find a wire that runs down the suspension to each wheel hub. That wire is for the ABS system, and the speed sensor is inside the wheel hub. If you follow those wires up from the hub you'll find a connector. Chances are that the connector is corroded and just needs cleaning, or the wire has been broken by road debris. Then again, maybe a sensor or two has gone south. I'd look for the obvious wiring break or corroded connector first, before turning the car over to a service tech. Good Luck! Quote Link to comment Share on other sites More sharing options...
capnfred Posted August 26, 2010 Share Posted August 26, 2010 If the abs lite is on pull the code, it will tell exactly what is not right.....good luck Quote Link to comment Share on other sites More sharing options...
fpny Posted August 26, 2010 Share Posted August 26, 2010 What do you use to pull the code? Quote Link to comment Share on other sites More sharing options...
