Drivers Window,
planman67
I have an 01 RX that will go down like a dream, however, it will not go up. If you go down a little, not auto, then try to switch it up it will go down a little at a time. Then try up again, goes down a little again. It does this until it finally reaches the bottem. It will not go back up immediately. I have to wait a while then it will finally go back up. I do hear it making a slight "click". I took the assembly apart and cleaned it, did not spray into the pins though.
Do you think this is the switch, motor or relay. The people we bought it from 3 years ago said it had always had some window issues but I think that was mainly track and the fact it was really loud. I will do the work myself, just need to figure out what to clean, fix or replace.
Thanks
  • 1 month later...
