CA913 Posted August 2, 2010 Share Posted August 2, 2010 A few weeks ago, my car sat for three days in the heat (90-100 degrees) outside, which is not usually the case, it's normally garaged. Anyhow the battery died and my husband had to jump my Lexus RX330 several times to use it, until we had the chance 2 days later to aquire a new battery. The new battery is in, but (coinsidently or not...) From the drive door controls the back windows won't open. The Windows are working fine when the controls on the back doors are used. The manual does not make mention of a fuse that is limited to my situation. Any thoughts as to what I might check other than the fuses before heading off to the dealer. Looking forward to any recommendations, Many thanks. CA913. Quote Link to comment Share on other sites More sharing options...
CA913 Posted August 2, 2010 Author Share Posted August 2, 2010 I called the local dealer, they recommended starting the vehicle and then going to each window and opening and closing the window three consecutive times, all the while holding the button up/down while in the process of opening/closing the windows. The theory was it would reset the system. I did and it did not work. Again, any suggestions would be greatly appreciated. Quote Link to comment Share on other sites More sharing options...
DubbyM Posted August 3, 2010 Share Posted August 3, 2010 I recently replaced my battery and the same thing happened. A few days later they began to work correctly all by themselves. I didn't do anything but wait. I hope yours are working now. Quote Link to comment Share on other sites More sharing options...
CA913 Posted August 8, 2010 Author Share Posted August 8, 2010 I recently replaced my battery and the same thing happened. A few days later they began to work correctly all by themselves. I didn't do anything but wait. I hope yours are working now. Quote Link to comment Share on other sites More sharing options...
CA913 Posted August 8, 2010 Author Share Posted August 8, 2010 Waiting has not resolved my particular situation, I'll be taking the RX330 for service and will share my problem/solution for the forums future reference. Many thanks for your support Quote Link to comment Share on other sites More sharing options...
rme Posted August 11, 2010 Share Posted August 11, 2010 A few weeks ago, my car sat for three days in the heat (90-100 degrees) outside, which is not usually the case, it's normally garaged. Anyhow the battery died and my husband had to jump my Lexus RX330 several times to use it, until we had the chance 2 days later to aquire a new battery. The new battery is in, but (coinsidently or not...) From the drive door controls the back windows won't open. The Windows are working fine when the controls on the back doors are used. The manual does not make mention of a fuse that is limited to my situation. Any thoughts as to what I might check other than the fuses before heading off to the dealer. Looking forward to any recommendations, Many thanks. CA913. I have an 05 and my book says roll the windows half way down then up and that should take care of your problem. It worked for me. Right now I'm trying to find out what's going on with my headlights since I had to change a battery out... Quote Link to comment Share on other sites More sharing options...
