I Have A Problem In The Fuse Of Etcs-I..!
Hi
I have gs300 model 2004. I have a problem in the fuse of ETCS-i.The problem is when Begin to drive a car for an indefinite period or when you run the air conditioner problem arises disable system ETCS-i and operate the bulb check engine light and VSC & VSC OFF, and when you check a fuse is burnt, but when you run the car and not to drive it the system ETCS-i is Ok. When you check the car (hand-held tester) before you burn the fuse there is no problem.
Please Please help me...
There have been some major issues with Toyota's ETCS(-i) system in the past. It's a vital component of the electronic drive-by-wire system, so you don't want to 'experiment' with it.
Take it to a lexus dealer for inspection and safety reasons.
In Saudi Arabia Lexus company do not have the experience they are just collecting money and the company change many things without any explanation. And I've got me too many problems with the company due to maintenance.
