caji Posted July 30, 2010 Share Posted July 30, 2010 Hi, I need some guidance from you guys on how to proceed on solving my handbrake warning light staying on. I suspect the handbrake switch or the brake fluid sensor switch might be shorted. Can somebody point me where to find the repair on the All Data site. Hope to hear from you guys. Quote Link to comment Share on other sites More sharing options...
DBrucher Posted July 30, 2010 Share Posted July 30, 2010 Fill your brake fluid reservoir to the tip-top. The sensor on mine is extra...sensitive and the dash light will show if the level isn't completely full. Give that a shot. Quote Link to comment Share on other sites More sharing options...
caji Posted July 30, 2010 Author Share Posted July 30, 2010 Fill your brake fluid reservoir to the tip-top. The sensor on mine is extra...sensitive and the dash light will show if the level isn't completely full. Give that a shot. I tried that nothing happens. I think I have to trace the wiring for the handbrake switch. I probably have to remove the console to get into the switch. Thanks for the reply. Quote Link to comment Share on other sites More sharing options...
caji Posted August 3, 2010 Author Share Posted August 3, 2010 I finally got my brake warning light to turn off. I have a rubber hose to the caliper leaking fluid. I end up changing that and it solved the problem. You are right DBrucher. If you have a small leak in the system it will trigger the warning light. So guys if your brake warning light is on, it means there is something wrong in your brake system. The handbrake switch seldom breaks. Quote Link to comment Share on other sites More sharing options...
DBrucher Posted August 3, 2010 Share Posted August 3, 2010 Glad it all worked out for you. Quote Link to comment Share on other sites More sharing options...
