Help
ja73
I have a 98 GS400 and I recently changed the camshaft seals because they started leaking. I marked every position of every part I removed and torqued everything to specs and when I started it it ran smoothly until it heated up then I started getting valve noise later I discovered I was getting little to no oil to the right side of the engine what could cause this and since it idle in that condition three to four times four mechanics to diagnos it do you think that there is serious damage to the lifters. also where does the oil come from to lube the lifters?
