Sign in to follow this
JWhite
95 Ls 400 Won't Start
Cranks but does not fire up. Sometimes I would hear a spinning noise in the starter when I would start her up so that leads me to thinking it is the starter. Maybe there could be an ignition problem. Any simple tests to do at home that might give me an idea?
Share this post
Link to post
Assuming that the engine is cranking over robustly, it is not a starter issue. Is it even trying to run? Simple tests would be checking for spark and fuel. Pull a spark plug wire from each bank and check for spark. If no spark, you can start chasing ignition issues. If you have spark, get a can of starter fluid and spray into the air intake while cranking. If it momentarily runs, you have fuel issues. This does not nail down the precise problem but does get things isolated.
Share this post
Link to post
Share this post
Link to post
Engine is cranking over robustly, no problem there, but does not even try to start. I will do the tests that you suggested and see where we stand. Thanks
Share this post
Link to post
Fuel pressure was fine but no spark. Turned out to be the crank position sensor. Back on the road again.
Share this post
Link to post
Loading...
