Light Under Shifter Not Working..
Benjerman123
You won't find a fuse that is dedicated to this one bulb. I replaced the shift indicator bulb on our Camry a few months ago -- wasn't all that hard. The shift indicator bulb on the IS300 looks like it is about the same place as in our Camry -- see the attached diagram for the 01 IS.
Don't know the bulb replacement procedure for the IS but it was a matter of shifting the Camry into neutral and pulling the shifter surround upward to get to the bulb underneath.
