Problem With Condensation
Seems like a common problem. If you are still within warranty, run don't walk to the dealer and get it replaced. If the warranty is over, I've heard of some successes with Lexus Customer Satisfaction and potentially escallating to Lexus Corp Pres. There is some persistence and hard work involved going down that path though.
Otherwise, buy another one like you said or live with it.
okay only on my passenger side im getting condensation in the main head light and in the highbean headlight, does any one else have this problem and what is the solution other than buying a whole new housing,
I BELIEVE THE PROBLEM IS WITH THE BREATHER THAT HANG BEHIND THE HOUSING OF THE LIGHT. SEE IF YOU CAN TAKE THEM OFF AND CLEAN THEM OFF. THAT SHOULD HELP. GOOD LUCK.
