obaida Posted May 7, 2010 Share Posted May 7, 2010 I have RX330 2004. the AC is working fine (Auto mode) but after some time when the tempreature inside the car is near to the desired tempreature and the fan at the low level. no cold air come and i have tio turn the AC for 15 min it will work. i notice some ice (freez ) on the AC pipe. it seems that te compressor still running (not clicking) please advice Quote Link to comment Share on other sites More sharing options...
sktn77a Posted May 7, 2010 Share Posted May 7, 2010 Sounds like you are low on refrigerant (vapor line freezing over). Quote Link to comment Share on other sites More sharing options...
obaida Posted May 9, 2010 Author Share Posted May 9, 2010 Sounds like you are low on refrigerant (vapor line freezing over). the problem start before 14 days , when i felt that the cool air is comming from the passenger side is coller than from my side. i went to the workshop and they told me taht there is a leak in the evaporater. i replaced the evaborter then the i faced this problem (vapor line freezing over). i went back to the workshoop and he told me this is beacuse of the THERMISTOR COOLER inside the dashboard. i would not like to remove the dashboard again . is there any solution . when i made AC SELF-DIAGNOSTICS , i got the following code 11 13 46 please advice Quote Link to comment Share on other sites More sharing options...
