PlanGK Posted April 30, 2010 Share Posted April 30, 2010 Okay so I was putting everything back together after trying to get to the rear valve cover gasket. I couldn't figure out how to get that large harness out of the way. But when I couldn't figure out why I couldn't find a spot to plug in a particular hose I came to check the tutorial and saw that I had somehow broke off a piece where the hose would have gone. Can anyone tell me what I need to replace to fix this I have no idea what it's called. The yellow arrow is where the hose would be connected. Okay I took the part out and heres what it looks like by itself. The third picture I have a green arrow pointed to the break point. This is where the hose would have went. Anyone know what this part is called? Quote Link to comment Share on other sites More sharing options...
PlanGK Posted April 30, 2010 Author Share Posted April 30, 2010 oops didn't mean to reply to my own post lol, meant to edit the first one. Quote Link to comment Share on other sites More sharing options...
George_Jetson Posted May 1, 2010 Share Posted May 1, 2010 That is called "VSV" (vacuum switching valve). It is used to control the variable induction system. There is a vacuum controlled valve at the passenger side of the intake plenum, it controls a butterfly valve (looks like a throttle plate), inside the intake plenum. It is used to control the effective intake runner length. At lower rpm's you want a longer intake to allow the momentum of the airflow to help fill the cylinders. At higher speeds you want shorter runners that allow for better filling. The ECM controls the valve. Quote Link to comment Share on other sites More sharing options...
PlanGK Posted May 1, 2010 Author Share Posted May 1, 2010 Thanks, I plan on heading over to the junkyard today. Hopefully I can find one. Quote Link to comment Share on other sites More sharing options...
