1996 Es 300
I would suggest moving this question to the ES forum.
Second, you might first check for fault codes, as this could be a faulty wheel-sensor, ABS-pump etc.. Btw, brakes work very well without ABS, as it's purpose is to keep the wheels from blocking completely...
  • 3 weeks later...
i say the same too just get your abs sensor clean if you dont really have any problems stoping the sensor on your abs is dirty :unsure: and need to be clean
Have either of you had either axle on either side replaced?
