Sign in to follow this
Mark Z
2002 Gs-300 Drivers Door Panel Removal
I need to get into the window master switch on the driver's side. Can anyone tell me where to start to remove the door panel? Looks like could do some serious damage if I start prying around. Thanks.
Share this post
Link to post
Make sure you windows are rolled down, it'll be easier.
There are some 10mm screws on the bottom and on the side; there's about four of them. Once those are off you can just pull the panel out, and you have to unplug the harness. It'll still be stuck, just lift the door panel up.
Share this post
Link to post
Thanks. I appreciate that.
Share this post
Link to post
Loading...
