opchiasm Posted March 27, 2010 Posted March 27, 2010 Thanks in advance for any help. I've read the manual, read posts, and am still having trouble. Basically, I want to know the quickest/easiest way to find a list of the closest Starbucks while driving. It seems like the most basic function to me, but I just can't get the system to do it. Perhaps part of the problem is that I've been using a Garmin for some time and haven't grasped a new system. Also, I'm stupid. In any event, I'd very much appreciate any guidance. No pun intended. Thanks.
ptsagcy Posted April 8, 2010 Posted April 8, 2010 Why not just call Enform? They are great and will download right to your Nav while you are driving. Otherwise, you will probably have to pull over and stop to do it yourself.
Art Giroux Posted April 11, 2010 Posted April 11, 2010 Thanks in advance for any help. I've read the manual, read posts, and am still having trouble. Basically, I want to know the quickest/easiest way to find a list of the closest Starbucks while driving. It seems like the most basic function to me, but I just can't get the system to do it. Perhaps part of the problem is that I've been using a Garmin for some time and haven't grasped a new system. Also, I'm stupid. In any event, I'd very much appreciate any guidance. No pun intended. Thanks. I have had the same problem. The only way that I have found around it is to pull over and stop. Then all of the features become active again. I guess it's a safty thing they don't want you fooling with it while driving. Would like to hear if their is a way around it.
cargopants Posted September 10, 2011 Posted September 10, 2011 You could try the following voice commands after pressing the Voice button: "Command List" "Show Coffee Houses" This should light up icons for coffee houses, including Starbucks. Then you can use the Remote Touch to click on one of them, press Enter, then Go To. At that point the navigation will prepare a route for you. I got this from the Navigation manual page 55, and then the chart of commands from pages 56 to 63 If you go to Starbucks often enough, you could leave the Coffee House icons lit up all the time...
iralynn Posted October 24, 2011 Posted October 24, 2011 Thanks in advance for any help. I've read the manual, read posts, and am still having trouble. Basically, I want to know the quickest/easiest way to find a list of the closest Starbucks while driving. It seems like the most basic function to me, but I just can't get the system to do it. Perhaps part of the problem is that I've been using a Garmin for some time and haven't grasped a new system. Also, I'm stupid. In any event, I'd very much appreciate any guidance. No pun intended. Thanks. I have had the same problem. The only way that I have found around it is to pull over and stop. Then all of the features become active again. I guess it's a safty thing they don't want you fooling with it while driving. Would like to hear if their is a way around it.
iralynn Posted October 24, 2011 Posted October 24, 2011 I don't think you're stupid, Lexus is. They designed the car as your mother , to prevent you from hurting yourself. There is an override available here is the link...............http://www.prestigioussociety.com/. I installed this myself. They seem to be available 24/7 in case you need help. I have owned 4 RX's....this is my last. They have eliminated good features that were on previous models. The RX is no longer a luxury suv. Lexus is NOT pursuing perfection....they are pursuing the dollar.
164287356 Posted October 26, 2011 Posted October 26, 2011 using voice control follow the voice guidance you will finally got what you need
