android0103 Posted March 17, 2010 Share Posted March 17, 2010 Today is March 14th, 2010. I own a 1999 Lexus RX300 with only 21,000 miles. I recently got a "check engine light" so I stopped at AutoZone for the free scan and got "P0500 Vehicle Speed Sensor". For the past week when I first get in it for the day. The transmission shifts at 3-4000 rpm.. much later than normal. It only does this for the first shift out of first and sometimes second gear. After that everything shifts normal. The check engine light will stay on for anywhere from 1 hour to 1 day, go off, then not come on for another 3 days, then suddenly there it is again. I know that there are two VSS's. From what I have read, if the speedometer is not working, it is the sensor with the 3 prong connector that is bad. The one that looks like this ----> http://shop.advanceautoparts.com/web...980-_-10720525 Since my speedometer is working perfectly, is it the sensor with 2 prongs that I need to replace? The one that looks like this? ----> http://shop.advanceautoparts.com/web...980-_-10720525 Thanks so much in advance for any help! I'm assuming if I get the correct information from this forum and I'm able to replace this myself, I will same myself several hundreds of dollars! Quote Link to comment Share on other sites More sharing options...
lenore Posted March 17, 2010 Share Posted March 17, 2010 see this posting from the club lexus site.... http://www.clublexus.com/forums/rx-first-g...ensor-help.html Quote Link to comment Share on other sites More sharing options...
bobgailw Posted March 14, 2011 Share Posted March 14, 2011 Today is March 14th, 2010. I own a 1999 Lexus RX300 with only 21,000 miles. I recently got a "check engine light" so I stopped at AutoZone for the free scan and got "P0500 Vehicle Speed Sensor". For the past week when I first get in it for the day. The transmission shifts at 3-4000 rpm.. much later than normal. It only does this for the first shift out of first and sometimes second gear. After that everything shifts normal. The check engine light will stay on for anywhere from 1 hour to 1 day, go off, then not come on for another 3 days, then suddenly there it is again. I know that there are two VSS's. From what I have read, if the speedometer is not working, it is the sensor with the 3 prong connector that is bad. The one that looks like this ----> http://shop.advanceautoparts.com/web...980-_-10720525 Since my speedometer is working perfectly, is it the sensor with 2 prongs that I need to replace? The one that looks like this? ----> http://shop.advanceautoparts.com/web...980-_-10720525 Thanks so much in advance for any help! I'm assuming if I get the correct information from this forum and I'm able to replace this myself, I will same myself several hundreds of dollars! Quote Link to comment Share on other sites More sharing options...
bobgailw Posted March 14, 2011 Share Posted March 14, 2011 where are the vvs sensors located on the lexus rx 300? Quote Link to comment Share on other sites More sharing options...
