camlex Posted March 15, 2010 Share Posted March 15, 2010 Hello, Yesterday CEL and TRAC both light came on, due to sunday, I continue driving. fill up some Chevron Gas. This morning turn car on to go to Autozone to check codes. No more lights. Any ideas? Thanks in advance. Quote Link to comment Share on other sites More sharing options...
George_Jetson Posted March 15, 2010 Share Posted March 15, 2010 Sounds strange, I am very surprised that there would be no stored codes. It might possibly be a quirk of the model code reader that Autozone used. It probably is not anything to be too concerned about, but if you are really curious you could purchase a recorder. Recorders plug into the OBDII port and records the data stream, depending on the amount of memory, the storage can cover a long period of driving. Professional scanners have had this function for a long time. I have just found out about the hobby version a short time ago. You can pick them up for around $60, and there is a interface that plugs into you PC compatible computer. Quote Link to comment Share on other sites More sharing options...
camlex Posted March 16, 2010 Author Share Posted March 16, 2010 Thank you. I went oreilly and requested to check memory code. His answer was without CEL He can't check. after 2nd request he connected and shows P0420 Bank 1. I don't think Cat goes bad this early at 138,000. Well, Presently no light and i am going put so many miles tomorrow, see what happens. usally CEL light come back 50-100 miles correct? Again, Thank you. Quote Link to comment Share on other sites More sharing options...
George_Jetson Posted March 16, 2010 Share Posted March 16, 2010 You are welcome, glad I could help you in the past. I suspected that there was a stored code. I am not too surprised that the guy at oreilly was mistaken, a lot of people do not understand how it is suppose to work, and I feel that some of the basic scanners are a little misleading, and only add to the confussion. You are correct that P0420 is for the cat efficiency but the cat is not the only problem that could set the code. To explain the basic operation of the system, The upstream O2 sensors are used to controll the fuel to air mixture. The Ecm varies the mixture from rich, to lean, trying to keep the upstream sensors switching continuously. The downstream O2 sensors are located after the cat, and they also monitor the switching from rich to lean. The cat uses the excess O2 to complete combustion of the exhaust gases so as a result the downstream sensor will switch at a slower rate than the upstream. With this in mind, the you first need to check the upstream sensors, and the exhaust system for leaks, and next the downstream sensor. Have the O2 sensors been replaced? They recommend replacing them around 80k, so they would be the first suspect. Quote Link to comment Share on other sites More sharing options...
George_Jetson Posted March 16, 2010 Share Posted March 16, 2010 . Quote Link to comment Share on other sites More sharing options...
camlex Posted March 17, 2010 Author Share Posted March 17, 2010 CEL and TRAC lights came back after 200 miles and Code is P0420 O2 sensors or CAT.? Thanks, Quote Link to comment Share on other sites More sharing options...
George_Jetson Posted March 17, 2010 Share Posted March 17, 2010 In order to tell exactly what is going on, you are going to need a scanner. First you need to check the upstream sensors, the exhaust system for leaks, and then the downstream sensor. Have the O2 sensors been replaced? They recommend replacing them around 80k, so they would be a strong possibility. A scanner is necessary to figure out exactly what is going on. Quote Link to comment Share on other sites More sharing options...
camlex Posted March 18, 2010 Author Share Posted March 18, 2010 Update: Since daughter taking car to austin, I don't want any phonecalls from her. P0420 was the code. Local shop replaced Cat with CATCO cat. total cost was $200. Model#608216 Thank you for your inputs. Quote Link to comment Share on other sites More sharing options...
George_Jetson Posted March 18, 2010 Share Posted March 18, 2010 Please do me a favor and keep me send me a update in the next couple months. Thanks Quote Link to comment Share on other sites More sharing options...
camlex Posted March 19, 2010 Author Share Posted March 19, 2010 you think light will come back? Quote Link to comment Share on other sites More sharing options...
George_Jetson Posted March 19, 2010 Share Posted March 19, 2010 I would hope not, but it is possible. I have never had the opportunity work on this code. I would find it very interesting to put a scope on both sensors at the same time. Quote Link to comment Share on other sites More sharing options...
camlex Posted March 19, 2010 Author Share Posted March 19, 2010 Last month, my sienna had P0135 CEL code at 157,000 and i did replaced both O2 sensors. Quote Link to comment Share on other sites More sharing options...
