Cost For "drain The Pan" & Refill With Amsoil Fluid.
Hello,
Pardom me if this question was asked before. I did some search but did not find the suitable answer (perhaps, my search criteria was wrong).
Any way...........I asked the local independent mechanic shop to give me 2 quotes(but, he gave me 3). Here are the prices...........
# 1 "Drain the Pan" & Refill With appropriate Toyota fluid (type IV) $65(approx.)
# 2 "Drain the Pan" & Refill With AMSOIL fluid $90(approx.) I want to do this --------again,Thanks a LOT .........Lexusfreak for GREAT advice
# "Drain the Pan" & Refill With AMSOIL fluid + Replace the filter $165(approx.) I thought, the Lexus 2002 ES 300 has NO filter , just a mesh or screen. Do you think I MUST also change this filter/mesh/screen NOW? . Please NOTE that my car has 80000 miles and I NEVER did drain & refill.
After this, I will do MULTIPLE drain and refill as suggested by LexusFreak. Thanks a LOT .........Lexusfreak for GREAT advice :cheers: .
Thanks a LOT.
:cheers:
Vic
you don't need to change the screen.
let's do some math here:
the transmission holds about 11 quarts of ATF
a drain & refill will only replace about 4 quarts.
1x drain & refill = 35% displacement of old ATF w/Amsoil
2x drain & refill = 50% dispalcement of old ATF prior to any changes w/Amsoil
so u drain & refill, then drive around for a week or so and do that again = 50% displacement of old ATF
the $90 service is probably not going to do you much good. you really need about 90% Amsoil ATF in there to be effective
here is what i did
1. drain
2. unplug the transmission coolant hoses and turn on the engine to let more ATF pump out
3. refill w/Amsoil ATF, idle the engine for 5 min to let the ATF mix well and repeat step 1 and 2
4. refill w/enough Amsoil ATF
5. final result is 90% Amsoil ATF or greater
6. now your ATF is good for another 50K miles
Hello,
Thanks a LOT.
I will tell my mechanic as exactly suggested by homemechanic - he gonna think I am a smartaxx - but I am OK with it , it is my car after all.
Both of you are TTTTTTTTTTTTTTEEEEEEEEEEEEEROFIC.
:cheers::cheers:
Vic
I agree with what home said ^...and the transmission filter mesh screen just needs to be cleaned, not replaced.
:cheers:
