dbirk Posted January 28, 2010 Posted January 28, 2010 As I was pulling in to my parking spot I heard a crack noise down by the clutch pedal. So I reached down there to see if I could figure out what it was, and sure enough my clutch pedal spring had broke. Anyone know where I can buy this? I've Google searched for an hour now, so I figured I'd go the the pros!!! Thanks for any suggestions!
IanH Posted January 28, 2010 Posted January 28, 2010 As I was pulling in to my parking spot I heard a crack noise down by the clutch pedal. So I reached down there to see if I could figure out what it was, and sure enough my clutch pedal spring had broke. Anyone know where I can buy this? I've Google searched for an hour now, so I figured I'd go the the pros!!! Thanks for any suggestions! The dealer is the easiest, should not be that much. you can check the online Lexus parts sites for a ball park cost.
1990LS400 Posted January 28, 2010 Posted January 28, 2010 I can't find the clutch springs either at the usual online Lexus parts websites. Someone on the MyIS forum listed the price at $2.26 so maybe it's too cheap for an online seller to carry. I actually found two clutch springs in the diagram and parts list -- I checked for a 2005 IS300 since you didn't give the year of your car. I assume you need the much larger of the two clutch springs. Both are shown in the attached 2005 IS300 clutch pedal assembly diagram. Sounds like it is time for a trip to Montgomery.
