Swampy11 Posted January 14, 2010 Posted January 14, 2010 I want to use Redline pure synthetic ATF in my `08 ES 350. Their specifications meet Toyota Type T-III & T-IV ATF. Does this meet Lexus' specifications? Thanks in advance. `swamp
Lexusfreak Posted January 15, 2010 Posted January 15, 2010 I want to use Redline pure synthetic ATF in my `08 ES 350. Their specifications meet Toyota Type T-III & T-IV ATF. Does this meet Lexus' specifications?Thanks in advance. `swamp No...you can't use that ATF in your ES 350 as it's a completely different ATF...you will need a fluid that meets Toyota WS (World Standard) specs (double check your owners manual). Other than Toyota, the only other possibility I know of is Amsoil. More info here... http://www.amsoil.com/storefront/atl.aspx And welcome to LOC. :)
SW03ES Posted January 21, 2010 Posted January 21, 2010 I would not put anything but the OEM fluid in there...sure fire way to cause warranty problems...
joeb427 Posted January 21, 2010 Posted January 21, 2010 I would not put anything but the OEM fluid in there...sure fire way to cause warranty problems... True! I'm a Amsoil fluids guy but wouldn't use anything but Toyota WS in the trans. WS is super expensive too.
Lexusfreak Posted January 21, 2010 Posted January 21, 2010 True!I'm a Amsoil fluids guy but wouldn't use anything but Toyota WS in the trans. WS is super expensive too. How much does Toyota charge for it per qt.?
joeb427 Posted January 21, 2010 Posted January 21, 2010 True!I'm a Amsoil fluids guy but wouldn't use anything but Toyota WS in the trans. WS is super expensive too. How much does Toyota charge for it per qt.? I read a year or so ago the WS is $42 a gallon.
KBRX330 Posted January 21, 2010 Posted January 21, 2010 The Toyota dealer I go to here sells me WS for $82 for a case of 12 quarts which is enough for a trans fluid exchange. (11.4qts)
