I have the plan to remove the radio console, but i need also the plan for the center arm rest so i can pass the VML device to the storing case, can somebody relay me to the proper link. The car is an ES350 2008.
thank you.
Maybe the attached diagram will help a little -- it's for a 2007 ES350 but it should be the same or close. The visible trim on consoles in Lexus/Toyota vehicles is usually held in place by friction fittings and removed by gently prying upward. I use either a plastic trim removal tool or a stiff blade putty knife with the blade covered with electrical tape to prevent scratching the trim.
You are the man, exactly what i need. If i may ask, where did you find that diagram and others if i need consultation. thank you again. I want to find a place to put the Vais MVL module without drilling holes since the wires supplied is kind of short.
  • 4 months later...
