Hi, my radio does not turn on at all, everything else in the car works, i checked both fuses and they both work. The Cd changer in the trunk works. The last thing I did to the car was open the back trunk and threw groceries behind the panel (behind the black cover on the trunk on the driver's side). Later I checked to see if I accidentally hit a wire, but there are no wires on that side for the radio that I saw. I threw it there before and nothing happened. It's weird because the radio just doesn't turn on at all and the lights don't turn on on the cluster only the power button for it lights up, all the other lights on the instrument cluster work though. What should I do next?
also, this is a pioneer system. sc400
Yeah the radios on these cars go bad especially if they are more then 10 years old.
Mine had died too then I bought a used Nakimichi one and that one died too so then i decided to go aftermarket and I bought an Alpine system that costed me $2400 for the head unit with toughscreen display,2 amps and a cd changer.
The cd changer went out a few months ago also and I had to send it in forrepair but now everything works perfectly again.
But you can go for a lo of cheaper stereos look on e bay for cheap head unit that has toughscreens touchscreens are better ad the Nav too.
I have Nav and an i Pod interface I can conrol my i Pod on my radio' toughscreens but unfortunatly my i pod died also.
