munna Posted December 26, 2009 Share Posted December 26, 2009 Hi, I am Hasan Indian, living in KSA. I have 1994 Lexus GS 300. My car won't start in cold weather it took 15 to 20 seconds after keeping the key in start position.Technician told have to change fuel filter, I replaced the filter but the problems continues. Itried to pull OBD codes through connecting jumper wire with TE1 and E1, transmission light was flashing 3 times and pause again one time flashed then a long pause. I am very far from the city, here the toyota dealer couldn't find the problem. Recently I changed the transmission filter and fluid, my mechaing filled the Ac Delco type ( H ) III instead of type T. I also clarified with the toyota mechanic he told nothing will happen with this oil. I will be very thankful if any one help me to find the solution. Quote Link to comment Share on other sites More sharing options...
sc400InTraining Posted January 22, 2010 Share Posted January 22, 2010 Hi, I am Hasan Indian, living in KSA. I have 1994 Lexus GS 300. My car won't start in cold weather it took 15 to 20 seconds after keeping the key in start position.Technician told have to change fuel filter, I replaced the filter but the problems continues. Itried to pull OBD codes through connecting jumper wire with TE1 and E1, transmission light was flashing 3 times and pause again one time flashed then a long pause. I am very far from the city, here the toyota dealer couldn't find the problem. Recently I changed the transmission filter and fluid, my mechaing filled the Ac Delco type ( H ) III instead of type T. I also clarified with the toyota mechanic he told nothing will happen with this oil. I will be very thankful if any one help me to find the solution. regarding you obd code that seems like code number 31, so now if you try to find a service manual for your specific model you should find out what that code stands for and how to fix the problem. As for the rest of your questions im not sure seeing as how your car is a GS model and not an SC model. Quote Link to comment Share on other sites More sharing options...
