marylandjd Posted December 26, 2009 Share Posted December 26, 2009 i recently decided to change the filter in the ls460l.I purchased the toyota tool to unscrew the housing.The service manual says that the tightening torque is about 30 ft-lbs.When I attemted to remove the housing,i needed a two foot breaker bar to turn it--probable closer to 100 ft.lbs.My first thought was that the lexus dealer had a rookie doing the work and he overtorqued it.I proceeded to replace the filter and torqued the housing to 30 ft-lbs.Within two days it began to leak.I removed the housing and replaced the o ring. and tightened it to spec.It continued to leak.i finally torqued it to 100 and it's been fine ever sense.Has any one had a similar experience.? Quote Link to comment Share on other sites More sharing options...
cmasten Posted December 27, 2009 Share Posted December 27, 2009 i recently decided to change the filter in the ls460l.I purchased the toyota tool to unscrew the housing.The service manual says that the tightening torque is about 30 ft-lbs.When I attemted to remove the housing,i needed a two foot breaker bar to turn it--probable closer to 100 ft.lbs.My first thought was that the lexus dealer had a rookie doing the work and he overtorqued it.I proceeded to replace the filter and torqued the housing to 30 ft-lbs.Within two days it began to leak.I removed the housing and replaced the o ring. and tightened it to spec.It continued to leak.i finally torqued it to 100 and it's been fine ever sense.Has any one had a similar experience.? The only thing I can think of is they cranked this down so tight the threads or housing is now damaged. You could either live with cranking it on there at 100lbs or purchase a new filter cap and see if that made a difference. Quote Link to comment Share on other sites More sharing options...
WhitSTer Posted December 27, 2009 Share Posted December 27, 2009 Kinda sounds like it might have been cross-threaded along the way. Whti Quote Link to comment Share on other sites More sharing options...
marylandjd Posted December 28, 2009 Author Share Posted December 28, 2009 Kinda sounds like it might have been cross-threaded along the way.Whti I noticed that you own a 460ls.Have you changed the filter and verified that the 30 ft-lbs torque spec is sufficient to keep it from leaking?I don't believe the housing is cross threaded.I watched the oil seal,and the mating surfaces on the housing and the engine and thought maybe the engine housing might be warped a hair,thereby causing the problem.i didn't have time to fully investigate the problem.By the way,I love your avatar.I hope you realize that if the obama team sees it,you will be branded a rt.wing radical,or possibly even a neo-!Removed! , and will not rexceive your stimulus check until the banks are fully satisfied and the wall street executive bonus' have been paid. Quote Link to comment Share on other sites More sharing options...
WhitSTer Posted December 28, 2009 Share Posted December 28, 2009 Kinda sounds like it might have been cross-threaded along the way.Whti I noticed that you own a 460ls.Have you changed the filter and verified that the 30 ft-lbs torque spec is sufficient to keep it from leaking?I don't believe the housing is cross threaded.I watched the oil seal,and the mating surfaces on the housing and the engine and thought maybe the engine housing might be warped a hair,thereby causing the problem.i didn't have time to fully investigate the problem.By the way,I love your avatar.I hope you realize that if the obama team sees it,you will be branded a rt.wing radical,or possibly even a neo-!Removed! , and will not rexceive your stimulus check until the banks are fully satisfied and the wall street executive bonus' have been paid. Actually I haven't yet. Only because I got a 'good will gesture' from corporate Lexus that provided the scheduled maintenances through 25,000 miles. I do already have six filters and am ready to go when those freebies expire after next maintenance. I'd seen the cross-threaded thing twice before ages ago. The threads were much too fine for a circumference of that size and was easy to cross thread the cannister. Was a lousy setup from the factory in the first place. Re: obama, yeah that would just be yet another screw-up in his farcical administration...and congress. Whit Quote Link to comment Share on other sites More sharing options...
2007ls460 Posted January 3, 2010 Share Posted January 3, 2010 i recently decided to change the filter in the ls460l.I purchased the toyota tool to unscrew the housing.The service manual says that the tightening torque is about 30 ft-lbs.When I attemted to remove the housing,i needed a two foot breaker bar to turn it--probable closer to 100 ft.lbs.My first thought was that the lexus dealer had a rookie doing the work and he overtorqued it.I proceeded to replace the filter and torqued the housing to 30 ft-lbs.Within two days it began to leak.I removed the housing and replaced the o ring. and tightened it to spec.It continued to leak.i finally torqued it to 100 and it's been fine ever sense.Has any one had a similar experience.? I have a 2007 LS460 with 42K miles. After the dealear changed my oil at 5K and 10K, I decided to do my own because of their sloppy work - they would leave oil smeared on the engine cover around the filler cap. Like you, at the 15K interval, I found that removing the filter housing took a hell of a lot of torque - Nothing like a professional doing the job and charging you $149. Ever since, I have been changing the oil every 5k and have not had any leaks. You have to make sure that o-ring stays in the housing grove when you tighten the housing. It is the o-ring that creates the seal and keeps the oil from leaking. I use a toyota filter ($10.42 at the Lexus dealer) and Mobil 1 0W-20 oil. Tourqing the oil canister to 100 ft-lbs is living dangerously - I torque my at around 30. Quote Link to comment Share on other sites More sharing options...
marylandjd Posted January 3, 2010 Author Share Posted January 3, 2010 i recently decided to change the filter in the ls460l.I purchased the toyota tool to unscrew the housing.The service manual says that the tightening torque is about 30 ft-lbs.When I attemted to remove the housing,i needed a two foot breaker bar to turn it--probable closer to 100 ft.lbs.My first thought was that the lexus dealer had a rookie doing the work and he overtorqued it.I proceeded to replace the filter and torqued the housing to 30 ft-lbs.Within two days it began to leak.I removed the housing and replaced the o ring. and tightened it to spec.It continued to leak.i finally torqued it to 100 and it's been fine ever sense.Has any one had a similar experience.? I have a 2007 LS460 with 42K miles. After the dealear changed my oil at 5K and 10K, I decided to do my own because of their sloppy work - they would leave oil smeared on the engine cover around the filler cap. Like you, at the 15K interval, I found that removing the filter housing took a hell of a lot of torque - Nothing like a professional doing the job and charging you $149. Ever since, I have been changing the oil every 5k and have not had any leaks. You have to make sure that o-ring stays in the housing grove when you tighten the housing. It is the o-ring that creates the seal and keeps the oil from leaking. I use a toyota filter ($10.42 at the Lexus dealer) and Mobil 1 0W-20 oil. Tourqing the oil canister to 100 ft-lbs is living dangerously - I torque my at around 30. Thanks for confirming that the filter will not leak if the housing is torqued to 30 ft-lbs.After i discovered the original leak,I removed the filter and housing at least three times in an attempt to ascertain what the problem was.I even changed the o ring all to no avail.Each tme i removed the housing , repositioned the o ring ,and then started the car,i could see the o ring being blown out by the oil pressure,generally at the same point on the ring.After the third time,i began to believe that the service manual was wrong and more torque was needed so I tightened it to about the same torque that the dealer did.In hindsight, maybe Whitster was correct----cross threaded housing. Quote Link to comment Share on other sites More sharing options...
2007ls460 Posted January 4, 2010 Share Posted January 4, 2010 i recently decided to change the filter in the ls460l.I purchased the toyota tool to unscrew the housing.The service manual says that the tightening torque is about 30 ft-lbs.When I attemted to remove the housing,i needed a two foot breaker bar to turn it--probable closer to 100 ft.lbs.My first thought was that the lexus dealer had a rookie doing the work and he overtorqued it.I proceeded to replace the filter and torqued the housing to 30 ft-lbs.Within two days it began to leak.I removed the housing and replaced the o ring. and tightened it to spec.It continued to leak.i finally torqued it to 100 and it's been fine ever sense.Has any one had a similar experience.? I have a 2007 LS460 with 42K miles. After the dealear changed my oil at 5K and 10K, I decided to do my own because of their sloppy work - they would leave oil smeared on the engine cover around the filler cap. Like you, at the 15K interval, I found that removing the filter housing took a hell of a lot of torque - Nothing like a professional doing the job and charging you $149. Ever since, I have been changing the oil every 5k and have not had any leaks. You have to make sure that o-ring stays in the housing grove when you tighten the housing. It is the o-ring that creates the seal and keeps the oil from leaking. I use a toyota filter ($10.42 at the Lexus dealer) and Mobil 1 0W-20 oil. Tourqing the oil canister to 100 ft-lbs is living dangerously - I torque my at around 30. Thanks for confirming that the filter will not leak if the housing is torqued to 30 ft-lbs.After i discovered the original leak,I removed the filter and housing at least three times in an attempt to ascertain what the problem was.I even changed the o ring all to no avail.Each tme i removed the housing , repositioned the o ring ,and then started the car,i could see the o ring being blown out by the oil pressure,generally at the same point on the ring.After the third time,i began to believe that the service manual was wrong and more torque was needed so I tightened it to about the same torque that the dealer did.In hindsight, maybe Whitster was correct----cross threaded housing. Does your housing screw in freely without much torque required before tightening? Usually when you have cross threading there is a lot of resistance during the first few turns. What I have noticed is that you have to be very carefull with the first few turns to make sure you are not cross threading. My experience is that after about 3 or 4 rotations by hand, it gets pretty snug, and I have to use a wrench to complete the installtion before the final torque. I agree with the others, this is a poor setup, toyota could have easily used a regular screw on filter like they do with many of their other models - our 2005 camry has a regular screw on fillter under the engine that is so easy to change. The Lexus oil change takes more time than it should. Plus that housing does not look like it is verey durable and over time may be subject to cracking and thread stripping(especially when the Lexus dealers tend to over tighten them) Quote Link to comment Share on other sites More sharing options...
marylandjd Posted January 4, 2010 Author Share Posted January 4, 2010 i recently decided to change the filter in the ls460l.I purchased the toyota tool to unscrew the housing.The service manual says that the tightening torque is about 30 ft-lbs.When I attemted to remove the housing,i needed a two foot breaker bar to turn it--probable closer to 100 ft.lbs.My first thought was that the lexus dealer had a rookie doing the work and he overtorqued it.I proceeded to replace the filter and torqued the housing to 30 ft-lbs.Within two days it began to leak.I removed the housing and replaced the o ring. and tightened it to spec.It continued to leak.i finally torqued it to 100 and it's been fine ever sense.Has any one had a similar experience.? I have a 2007 LS460 with 42K miles. After the dealear changed my oil at 5K and 10K, I decided to do my own because of their sloppy work - they would leave oil smeared on the engine cover around the filler cap. Like you, at the 15K interval, I found that removing the filter housing took a hell of a lot of torque - Nothing like a professional doing the job and charging you $149. Ever since, I have been changing the oil every 5k and have not had any leaks. You have to make sure that o-ring stays in the housing grove when you tighten the housing. It is the o-ring that creates the seal and keeps the oil from leaking. I use a toyota filter ($10.42 at the Lexus dealer) and Mobil 1 0W-20 oil. Tourqing the oil canister to 100 ft-lbs is living dangerously - I torque my at around 30. Thanks for confirming that the filter will not leak if the housing is torqued to 30 ft-lbs.After i discovered the original leak,I removed the filter and housing at least three times in an attempt to ascertain what the problem was.I even changed the o ring all to no avail.Each tme i removed the housing , repositioned the o ring ,and then started the car,i could see the o ring being blown out by the oil pressure,generally at the same point on the ring.After the third time,i began to believe that the service manual was wrong and more torque was needed so I tightened it to about the same torque that the dealer did.In hindsight, maybe Whitster was correct----cross threaded housing. Does your housing screw in freely without much torque required before tightening? Usually when you have cross threading there is a lot of resistance during the first few turns. What I have noticed is that you have to be very carefull with the first few turns to make sure you are not cross threading. My experience is that after about 3 or 4 rotations by hand, it gets pretty snug, and I have to use a wrench to complete the installtion before the final torque. I agree with the others, this is a poor setup, toyota could have easily used a regular screw on filter like they do with many of their other models - our 2005 camry has a regular screw on fillter under the engine that is so easy to change. The Lexus oil change takes more time than it should. Plus that housing does not look like it is verey durable and over time may be subject to cracking and thread stripping(especially when the Lexus dealers tend to over tighten them) As i recall ,i didn't encounter any unusual resistence when i was turning the housing .I first felt resistence when the o ring mated with the engine housing.I guess that's was why i was skeptical of any suggestion that the housing was cross threaded.If the housing wasn't cross threaded and the tightening torque was correct ,the only other thing i can think of that could cause the problen would be a distorted engine oil frame or oil housing frame..I'll be changing the oil in about two weeks.Unfortunately,i think the original housing was replaced when the short block and right cyclinder head had to be replaced after the mechanic at the lexus dealership dropped a bolt into the cyclinder and then took it out for a test drive.Now ,at least,i know that 30 ft-lbs of torque is correct.Thanks for your thoughts. Quote Link to comment Share on other sites More sharing options...
WhitSTer Posted January 4, 2010 Share Posted January 4, 2010 As i recall ,i didn't encounter any unusual resistence when i was turning the housing .I first felt resistence when the o ring mated with the engine housing.I guess that's was why i was skeptical of any suggestion that the housing was cross threaded.If the housing wasn't cross threaded and the tightening torque was correct ,the only other thing i can think of that could cause the problen would be a distorted engine oil frame or oil housing frame..I'll be changing the oil in about two weeks.Unfortunately,i think the original housing was replaced when the short block and right cyclinder head had to be replaced after the mechanic at the lexus dealership dropped a bolt into the cyclinder and then took it out for a test drive.Now ,at least,i know that 30 ft-lbs of torque is correct.Thanks for your thoughts. Jeeze, I think I'd point out the new problem and DEMAND another 2007, or better, they might have on the lot. How in the hell would a mechanic just "drop" a bolt into the cylinder??? If they balk, I'd threaten to go to the BBB, local Chamber of Commerce and Corporate Lexus. This is terrible from ANY dealer, must less a Lexus dealer. Whit Quote Link to comment Share on other sites More sharing options...
