97LS4003jg Posted December 16, 2009 Share Posted December 16, 2009 I have a 97 LS 400 with 98k miles on it that has a whine coming from the power steering pump area. The sound does NOT change much when the wheel is turned. I checked the fluid and all is fine. My independent mechanic said it looked fine when he did the 90k service recently. But it is still there. It is worse at idle and I can actually feel a little vibration through the wheel. So I just had all the work done and the problem is still there. I took it to another mechanic who said the belts where fine and agreed the pump was going out and change it. What should I do? I have one guy saying it is fine and another saying it is not. Could it be anything else? Thanks in advance. Quote Link to comment Share on other sites More sharing options...
someguy Posted December 16, 2009 Share Posted December 16, 2009 I wouldnt be surprised if it was the was pump. These cars have bad power steering pumps. Go ahead and change it. Quote Link to comment Share on other sites More sharing options...
90LS400Lexus Posted December 17, 2009 Share Posted December 17, 2009 I have a 97 LS 400 with 98k miles on it that has a whine coming from the power steering pump area. The sound does NOT change much when the wheel is turned. I checked the fluid and all is fine. My independent mechanic said it looked fine when he did the 90k service recently. But it is still there. It is worse at idle and I can actually feel a little vibration through the wheel. So I just had all the work done and the problem is still there. I took it to another mechanic who said the belts where fine and agreed the pump was going out and change it. What should I do? I have one guy saying it is fine and another saying it is not. Could it be anything else? Thanks in advance. Gotta love the power steering systems on the LS400s. ;) Seriously, if its whining and the fluid is full, it may be going out. Is the steering hard to turn? Power steering woes are no stranger to ANY LS400, but the 1990-1994 models seem to be plagued the most. Good luck and welcome to these forums. Quote Link to comment Share on other sites More sharing options...
amcdonal86 Posted December 17, 2009 Share Posted December 17, 2009 Agreed. My '97 had a loud popping sound on right turns, which thankfully was cured by changing the fluid. Quote Link to comment Share on other sites More sharing options...
RDM Posted December 17, 2009 Share Posted December 17, 2009 What kind of fluid is in it? That is the number one cause of issues, if you're running regular PS fluid, go ahead and replace the pump, flush the entire system, and refill with the correct fluid. Quote Link to comment Share on other sites More sharing options...
etex Posted December 17, 2009 Share Posted December 17, 2009 Before you spend that kind of money for a PS pump, better check the alternator for the source of the noise. I put the second PS pump on my '97 before discovering that was not the problem... was the alternator. Just my $.02. Quote Link to comment Share on other sites More sharing options...
McSwine Posted December 17, 2009 Share Posted December 17, 2009 Before you spend that kind of money for a PS pump, better check the alternator for the source of the noise. I put the second PS pump on my '97 before discovering that was not the problem... was the alternator. Just my $.02. Same here on my 2000. Quote Link to comment Share on other sites More sharing options...
97LS4003jg Posted December 17, 2009 Author Share Posted December 17, 2009 Thanks guys, love the forum been lurking for long time. On my third used LS....had a '92, '98, and now the '97 great cars. Well had the new pump put on and noise is still there :( Here is some more info, at speed no noise, at idle in gear with low RPM's no noise, in park at idle it whines. It is coming from the power stering pump side. No question something is going on because one day the noise just started. Could have sworn it was the pump because I have already replaced two in my previous LS and it is the same sound. Will check the alternator. Any other thoughts? Quote Link to comment Share on other sites More sharing options...
97LS4003jg Posted December 22, 2009 Author Share Posted December 22, 2009 I have a 97 LS 400 with 98k miles on it that has a whine coming from the power steering pump area. The sound does NOT change much when the wheel is turned. I checked the fluid and all is fine. My independent mechanic said it looked fine when he did the 90k service recently. But it is still there. It is worse at idle and I can actually feel a little vibration through the wheel. So I just had all the work done and the problem is still there. I took it to another mechanic who said the belts where fine and agreed the pump was going out and change it. What should I do? I have one guy saying it is fine and another saying it is not. Could it be anything else? Thanks in advance. Replacing the alternator fixed the problem at the expense of replacing steering pump as well. Thanks for all of the replies. Quote Link to comment Share on other sites More sharing options...
