Henri Luu Posted December 9, 2009 Share Posted December 9, 2009 Hello All, I got a 2004 Es330 with only a valet key and a key card with the key and key code. I assume that the key card is the master and also be able to program additional master key. I got a new master key cut from the key code at SPARE CAR KEY. It work perfectly: open the doors, lock and unlock the glove compartment. The only problems is the it will not start the engine nor unlock and lock wireless. I've try the gas (5 times) and brake (6 times) trick. but was not successful. Please help??????????? Please don't send me to the dealer. Thanks you Quote Link to comment Share on other sites More sharing options...
stcist2 Posted December 9, 2009 Share Posted December 9, 2009 Will it start when you hold the card close to the key? Quote Link to comment Share on other sites More sharing options...
pj8708 Posted December 9, 2009 Share Posted December 9, 2009 Hello All, I got a 2004 Es330 with only a valet key and a key card with the key and key code. I assume that the key card is the master and also be able to program additional master key. I got a new master key cut from the key code at SPARE CAR KEY. It work perfectly: open the doors, lock and unlock the glove compartment. The only problems is the it will not start the engine nor unlock and lock wireless. I've try the gas (5 times) and brake (6 times) trick. but was not successful. Please help??????????? Please don't send me to the dealer. Thanks you Hi, I have an 05' ES330, and if the owners manual is correct, your going to have to have a standard master key with the built in transponder in order to link up with the ignition/security module. This is the only way the car will start. Even though you told me not to, you will have to contact a dealer to have one made using your key code. Hope this helps PJ Quote Link to comment Share on other sites More sharing options...
Henri Luu Posted December 9, 2009 Author Share Posted December 9, 2009 Will it start when you hold the card close to the key? Yes, it will. Quote Link to comment Share on other sites More sharing options...
AndyNg Posted December 16, 2009 Share Posted December 16, 2009 Hello All, I got a 2004 Es330 with only a valet key and a key card with the key and key code. I assume that the key card is the master and also be able to program additional master key. I got a new master key cut from the key code at SPARE CAR KEY. It work perfectly: open the doors, lock and unlock the glove compartment. The only problems is the it will not start the engine nor unlock and lock wireless. I've try the gas (5 times) and brake (6 times) trick. but was not successful. Please help??????????? Please don't send me to the dealer. Thanks you Stealer will charge around $50.00 - $55.00 to program the keyless remote and the cut key... That's was what I did 2 weeks ago.... Quote Link to comment Share on other sites More sharing options...
camlex Posted December 17, 2009 Share Posted December 17, 2009 SPARE CAR KEY should send you "How to program" please try again. I did for my 00 ES300 and it's works like original. Hope that helps. Quote Link to comment Share on other sites More sharing options...
BJHafez Posted December 17, 2009 Share Posted December 17, 2009 SPARE CAR KEY should send you "How to program" please try again.I did for my 00 ES300 and it's works like original. Hope that helps. Hi camlex, Would appreciate getting the "how to program" instructions you used on your 00 ES300. I tried many versions (probably applicable to 97-99 model years) posted on this site but none worked on my 01 ES300. Thanks. BJ baj39 Quote Link to comment Share on other sites More sharing options...
McHefflin Posted March 27, 2010 Share Posted March 27, 2010 Does anyone out there have the instructions on how to program a transponder key (no remote) for a 2002 ES300? This is a spare key for my car. I have only one master key. Thanks! Quote Link to comment Share on other sites More sharing options...
