The Brightness and Contrast of the GPS display on my ES330 that changes with daylight or darkness stopped working. It is in night mode continuously. Any thoughts?
I would wonder if a reset of the Nav system wouldn't solve the problem and set every parameter back to its default state. It may well be that the software has got itself in a lockup situation on the screen parameters. You'll need to talk to a Lexus technician or check your manual to see if it provides the reset info procedures.
If that doesn't solve the problem you could have a bad screen which would need to be replaced, and it won't be cheap for sure.
Good Luck!
could be that envelope sittng on your dash? covering the daylight/night sensor?maybe.
