Powered Or Unpowered Tail Light Converters?
skongolf
I need to get a tail light converter for my 99 RX300 that has the tow package. As far as I can tell it does not have a seperate battery wire, so can I just use a Modulite or Curt that does not have the battery wire? What have you guys run? Also I can not find the tow fuse in the fuse box under the hood like other posts have said that is where it was located. Is the 99 tow fuse in a different location?
Thanks
Thank you for the print out. My question is though, Have the people who have used after market converters used the ones with a wire that goes straight to the battery or the one without? they make both that are circuit protected I just need to know what is better since the factory one isnt battery powered.
