Nagloc Posted October 11, 2009 Share Posted October 11, 2009 How do you remove the plastic housing in order to replace the filter, thanks? Quote Link to comment Share on other sites More sharing options...
skycaptain Posted October 11, 2009 Share Posted October 11, 2009 There are 4 simple lever clips on the Air Cleaner box. 2 on top and 2 on the bottom. Simply release these and the intake cover will slide back about 4 inches. After replacing the filter you must make sure the cover is aligned perfectly or you won't be able to get the clips tp grab. Changed my first air cleaner 2 days ago for the first time and it took me about 3 minutes because I had to wiggle the cover a couple of times to get it seated properly. Regards, Luke B) Quote Link to comment Share on other sites More sharing options...
metal Posted October 12, 2009 Share Posted October 12, 2009 There are 4 simple lever clips on the Air Cleaner box. 2 on top and 2 on the bottom. Simply release these and the intake cover will slide back about 4 inches. After replacing the filter you must make sure the cover is aligned perfectly or you won't be able to get the clips tp grab. Changed my first air cleaner 2 days ago for the first time and it took me about 3 minutes because I had to wiggle the cover a couple of times to get it seated properly. Regards, Luke B) My 08 appears to have three bolts holding down the hinged cover on the box? Quote Link to comment Share on other sites More sharing options...
skycaptain Posted October 12, 2009 Share Posted October 12, 2009 My car is an '07. Maybe they chaged the aircleaner box in '08 Luke There are 4 simple lever clips on the Air Cleaner box. 2 on top and 2 on the bottom. Simply release these and the intake cover will slide back about 4 inches. After replacing the filter you must make sure the cover is aligned perfectly or you won't be able to get the clips tp grab. Changed my first air cleaner 2 days ago for the first time and it took me about 3 minutes because I had to wiggle the cover a couple of times to get it seated properly. Regards, Luke B) My 08 appears to have three bolts holding down the hinged cover on the box? Quote Link to comment Share on other sites More sharing options...
skycaptain Posted October 12, 2009 Share Posted October 12, 2009 Also my engine is the 330...Luke B) Quote Link to comment Share on other sites More sharing options...
