2000 Ls400 Platinum Series
where can i tap into a 12v source that stays on when the car is on?
The wire leading to the power port in the console box is pretty easy to get to -- I spliced a 12V extension cord into it to which I plugged in my portable GPS. The console wood is easy to pry out to access the wire.
Another method is to use an "add-a-circuit" fuse in the underdash fuse box -- they are made to power accessories. If you get one, look for one that has the fuse in-line so that the fuse box cover will still snap on.
