Interior Lights
Is there a way to turn on all of the interior lights without opening a door on the 06 400h? In my Jeep (and every other car I've owned), all you did was turn the knob that dimmed the instrument cluster and you could turn all the interior lights on while driving. I know you can just turn on the map light, but I want to turn on all the lights.
I checked my manual and couldn't find any mention of that, although personally, I've never had the need to turn on the door or rear storage area lights while driving.
there is a three position switch on each ceiling interior light that has a door, off and on position. so you would have to turn the front and back ones on manually to the on postion while driving. do not forget to switch to door or off as the light will stay on and drain your battery after you leave the car.
