In cold weather, my 97 Lexus ES 300 will idle rough after traveling about 30 mph and then coming to a complete stop. The car will pulsate for a few seconds and then return to a normal idle. This only happens in real cold weather (28 degrees) and only during the first complete stop. The car starts fine, idles regular, and I also allow ten minutes for the car to warm up before driving.
Does anyone know what could be causing this problem? Any assistance is greatly appreciated b4 I take the car to the dealer. Thanks.
could be lots of things, all associated to fuel air mixture and delivery:
-dirty idle air control assembly (prone to carbon build up),
-dirty throttle body or lazy trottle position sensor
-lazy O2 sensor sending wrong info ECU, takes a second or two for the ECU to
catch up to the fuel air mixture difference at stop.
-could be a faulty crank or cam sensor
-lazy MAF sensor
-fuel pressure sensor
no CEL, right?
the only true way to diagnose what is going on is to have a scan tool hooked up to the car at the time it actually pulsates. This way you/a trained mechanic can actually pinpoint what is happening and what may be causing the pulsation.
steviej
i agree totally with steviej
check the idle control and clean it first extremly common problem with about 20 posts on the subject
