fritz1 Posted August 21, 2009 Share Posted August 21, 2009 Have 2007RX ,Anybody have idea how to take filter out to replace? It is not in owners man.as is told on filter container in engine Quote Link to comment Share on other sites More sharing options...
metal Posted August 23, 2009 Share Posted August 23, 2009 It appears you remove the two 10mm screws and pry the top of the box up to get at this filter. Quote Link to comment Share on other sites More sharing options...
fritz1 Posted August 24, 2009 Author Share Posted August 24, 2009 It appears you remove the two 10mm screws and pry the top of the box up to get at this filter. Quote Link to comment Share on other sites More sharing options...
RMB350 Posted August 25, 2009 Share Posted August 25, 2009 I have to change mine too. Looks like a real bear to do!! Had the new filter sitting on the work bench for three weeks and still haven't attempted it.. When you do change it, make sure that you do not knock off any vacuum lines, or if you do, make sure that they are connected when you're finished. This could set off the VSC light on the dash. Good luck!! Quote Link to comment Share on other sites More sharing options...
