New Battery- No Lights
Mooga1120
93 ES300- battery died & had to be replaced. Installed new battery , and nothing. No dash lights, dome lights, chimes, nothing. Any suggestions? IF it was installed backwards (which my b/f will never admit) what should be checked/ replaced?
Also-driver door went haywire and is locked, cannot be unlocked inside the car or w/ the key-this happened before the battery.
Thanks
Thanks
;)TRY ANOTHER BATTERY
Thanks,
Also car needs a new oil pan gasket & the part is only $5, but the shop quoted me $350 for labor. Is this right?
yes. as high as it is that's about two and a half hours worth of labor. Ask a toyota dealership and several independents shops in your area what they would charge, it will most likely be less. You can buy the part and bring it with you.
steviej
