I cracked my front door handle this past winter (frozen lock) and it was not a problem until the crack started getting bigger. So now I think I need to replace the handle. How do I do it?
follow the instructions, BUT be VERY careful when you remove the rod from the door lock, the other end is mounted in plastic, I broke mine, pulling too hard. had to buy the lock assy, I was lucky, found one at the salvage yard...
it is easy to replace the handle, but costly if you mess up.
good luck
