DuaneG Posted August 3, 2009 Posted August 3, 2009 I cracked my front door handle this past winter (frozen lock) and it was not a problem until the crack started getting bigger. So now I think I need to replace the handle. How do I do it?
AzHotLS Posted August 3, 2009 Posted August 3, 2009 http://www.lexls.com/tutorials/body/fdoorhandle.html
billydpowell Posted August 4, 2009 Posted August 4, 2009 follow the instructions, BUT be VERY careful when you remove the rod from the door lock, the other end is mounted in plastic, I broke mine, pulling too hard. had to buy the lock assy, I was lucky, found one at the salvage yard... it is easy to replace the handle, but costly if you mess up. good luck
