andayafox Posted July 30, 2009 Share Posted July 30, 2009 I m new here. i bought 92 sc300 5 speed like 2 months ago. i rode it a lot for work. that day D1 drifter at speedway then i was on way to there. later my sc300 got overheat like 5 min and off igiton and keep drive to speedway and let it cool down almost there speedway then i decide to on igition key and push clutch with stick 2 gear speed then wont run like wtf. but made it to park alot where in gas station. i left sc300 there to join my friend car to d1. later after d1 went to gas station for check if run and fill water of coolant but i saw leak then under of engine that was radiator. my friend got truck and tow my car to home. next day i remove radiator and fan for check on belt timing, spark, fuses, ignition, everything are fine cause i test run with spark plug was on and fuel pump is on too. i changed coil ignition. i research said EEC like ECU. if would change new ECU then would be run for real? If you know about what about wrong or need replace then contact me and Please help me out. thank you Quote Link to comment Share on other sites More sharing options...
Sc400=Delirium Trigger Posted August 4, 2009 Share Posted August 4, 2009 I m new here. i bought 92 sc300 5 speed like 2 months ago. i rode it a lot for work. that day D1 drifter at speedway then i was on way to there. later my sc300 got overheat like 5 min and off igiton and keep drive to speedway and let it cool down almost there speedway then i decide to on igition key and push clutch with stick 2 gear speed then wont run like wtf. but made it to park alot where in gas station. i left sc300 there to join my friend car to d1. later after d1 went to gas station for check if run and fill water of coolant but i saw leak then under of engine that was radiator. my friend got truck and tow my car to home. next day i remove radiator and fan for check on belt timing, spark, fuses, ignition, everything are fine cause i test run with spark plug was on and fuel pump is on too. i changed coil ignition. i research said EEC like ECU. if would change new ECU then would be run for real? If you know about what about wrong or need replace then contact me and Please help me out. thank you Have you checked the thermostat or the water pump? I had a friend that couldn’t figure out why his car was over heating (Pontiac Grand Prix) it took me like 5 minutes to realize DUH it was the thermostat it wasn’t opening to let coolant in. Hope that helps man Quote Link to comment Share on other sites More sharing options...
