riwyle Posted July 9, 2009 Share Posted July 9, 2009 When I apply my brakes on my '07 400hwhen close to a stop I often heat a chirp or squawk, which is annoying. I took the car to my local dealer and was given the oft heard answer, UTD (unable to duplicate). I just saw on the Internet, while looking for something else, that there is a TSB BR 003-07, Brakes chirp/squawk when applying pedal. Has anyone had this problem, had it repaired, and what is the nature of the repair. I do not subscribe to All Data, so I can't pull it up. I like to have as much info as possible when I go to the dealer. Thanks !Removed! L. Quote Link to comment Share on other sites More sharing options...
lemon Posted July 9, 2009 Share Posted July 9, 2009 When I apply my brakes on my '07 400hwhen close to a stop I often heat a chirp or squawk, which is annoying. I took the car to my local dealer and was given the oft heard answer, UTD (unable to duplicate). I just saw on the Internet, while looking for something else, that there is a TSB BR 003-07, Brakes chirp/squawk when applying pedal. Has anyone had this problem, had it repaired, and what is the nature of the repair. I do not subscribe to All Data, so I can't pull it up. I like to have as much info as possible when I go to the dealer.Thanks !Removed! L. Here ya go. Print it out and take it to the dealer. BR003_07.pdf Quote Link to comment Share on other sites More sharing options...
RX400h Posted July 10, 2009 Share Posted July 10, 2009 ...looks like I won't be bleeding the brakes by myself any time soon! Thanks foe posting that info, Lemon. Quote Link to comment Share on other sites More sharing options...
lemon Posted July 10, 2009 Share Posted July 10, 2009 No problem. Yes, it's not as simple as bleeding the brakes on a non hybrid vehicle which uses a brake booster powered by engine vacuum. Since the engine isn't always on the brake boosting is electric in the RX. Changing pads shouldn't be a problem (though there is a TSB about check lights activating after pad change) but bleeding I think is something the dealer may have to do. Quote Link to comment Share on other sites More sharing options...
emim Posted July 11, 2009 Share Posted July 11, 2009 THis was aswesome!! I actually took my 06 400h to the dealer Thrs and they said the same thing, can't duplicate it! PLUS, they charged me $58 (Lexus of Rockville Centre, NY) for lifting the car and "checking" the brakes!!! So I will be going back with the bulletin! Quote Link to comment Share on other sites More sharing options...
