Hobowon Posted July 5, 2009 Share Posted July 5, 2009 Big slam when slowing to stop - does it only when car is at idle speed just short of full stop (behind car in front, stopping at intersection, etc). If I can keep the rpms at the mark below the 1000 mark (consider the mark just below the 1000 mark), such as when the air is on or even when the tranny is in the "overdrive off" mode. Another way to avoid the "bang" is to make a harder stop; that isn't in line with my driving style but that is another way to avoid it. Lexus has checked it out four times, (Lexus) tranny fluid changed twice, have new drive shaft, differential mic'd and within limits, other gears tight, idle set by Lexus, throttle body cleaned. Sure could use some help and would be very grateful for suggestions. Thanks. Quote Link to comment Share on other sites More sharing options...
Cynical Posted July 6, 2009 Share Posted July 6, 2009 I would check you Torque Converter Quote Link to comment Share on other sites More sharing options...
