drewzer Posted July 5, 2009 Share Posted July 5, 2009 Hello, I have a 1999 RX300 and have been hearing a grinding noise coming from under the "dash" on the passenger side. It's really much closer to the floor though on the center console side. I have removed two plastic panels and I think I have isolated the grinding noise to what looks like a motor near these very hot metal rods. Does anyone have any idea what I'm talking about here? Without being able to identify my problem, it's hard to search for a solution. Any help is appreciated. Also, A/C is working fine but I'm hearing an annoying sound whenever it is on. Do I need to lubricate or replace a belt or something? Don't know if it could be related to above problem, but and advice on this would be welcome too. Thanks for your help. -Drew Quote Link to comment Share on other sites More sharing options...
Jeffstpetebeach Posted July 5, 2009 Share Posted July 5, 2009 Hello,I have a 1999 RX300 and have been hearing a grinding noise coming from under the "dash" on the passenger side. It's really much closer to the floor though on the center console side. I have removed two plastic panels and I think I have isolated the grinding noise to what looks like a motor near these very hot metal rods. Does anyone have any idea what I'm talking about here? Without being able to identify my problem, it's hard to search for a solution. Any help is appreciated. Also, A/C is working fine but I'm hearing an annoying sound whenever it is on. Do I need to lubricate or replace a belt or something? Don't know if it could be related to above problem, but and advice on this would be welcome too. Thanks for your help. -Drew Yes I do. I also have a 1999 Rx300 and I just did the two sevo motors. The bottom one is the for cold and hot mixer, the top one is the mode. I took mine apart and cleaned and regrease them works perfect. New ones around 150 Each. the bottom one is harder to get out, Quote Link to comment Share on other sites More sharing options...
Jeffstpetebeach Posted July 5, 2009 Share Posted July 5, 2009 Drew, Heres a file that should help you in your travels. The info your looking for starts on Page AC14. hope this helps Jeff Air_Conditioning__AC__file.pdf Quote Link to comment Share on other sites More sharing options...
drewzer Posted July 8, 2009 Author Share Posted July 8, 2009 Thanks, Jeff. I hope to look into this soon. Stay tuned... Drew,Heres a file that should help you in your travels. The info your looking for starts on Page AC14. hope this helps Jeff Quote Link to comment Share on other sites More sharing options...
