Monsieur Dupont Posted June 4, 2009 Share Posted June 4, 2009 Hi I am shopping for an aftermarket brake kit for a UCF10. This is not the well-documented brake upgrade using rotors from the JZA80. Below is what I have in mind, all hypothetical at this stage: Front 350mm one-piece rotor, cross-drilled six pistons Rear 280mm one-piece rotor, cross-drilled four pistons My question is about the compatibility of aftermarket calipers to the UCF10 LS 400 caliper braces... will they fit? What brands and models are known to fit? Upgrading to high-performance aftermarket brake systems is new territory for me. Also, I realize that I probably will have to change the wheels and tires to something bigger and wider to clear the new rotors and calipers. Thank you Quote Link to comment Share on other sites More sharing options...
