hey all. i want to swap out the turn signal bulbs with LEDs. does anyone know where the turn signal thermal flasher is location on an 3GS? has anyone done this swap before? thanks very much!
listen for the click to find it , i have all led's for my signals with a aftermarket relay so it can flash normally.
Wow - any chance you could post the part number you ordered and where you got it from for the flasher???? I am despereate to do the same thing... also, was the flasher behind the instrument cluster or behind the fusebox? Can you give us some detail????
Lee
We don't have the same car so a part number will not help you.
Like i said listen for the click to find it .
I have listened, and I even have a printout of the Service Manual, but I cannot triangulate where the relay sounds originates, unfortunately.... oh well.
Lee
