era57 Posted May 28, 2009 Posted May 28, 2009 Hey, guys. I have a '99 GS 400 and it seems that the accelerator pedal position sensor is on its way out...when I push down the gas it lurches a little until it finally reacts and at one point it totally gave out (luckily right around the block from my house), but having to drive back at 5mph sucked regardless. The car works now with the exception of the sensor being fickle soo I'm expecting it to give out eventually. Does anyone know how much this is going to cost me? I rather not have to wait until I'm stranded somewhere. :\ Any insight would be awesome. Thanks
1990LS400 Posted May 28, 2009 Posted May 28, 2009 If it is like my 00 LS400, there may be two sensors -- a pedal position sensor and a throttle position sensor. The two work together. It is hard to tell which is defective -- the "PPS" or the "TPS". I had both the PPS and the TPS replaced on my 00 LS a few weeks ago - The TPS was $113.99 and the "PPS" was $343.72. The TPS tested as bad and the PPS tested as marginal so I had them both replaced -- total including labor and diagnosis was about $670 before tax at the indie Lexus repair shop I've used the past 12-13 years. I almost got stranded too ... I stopped driving the car until I had it fixed.
era57 Posted June 1, 2009 Author Posted June 1, 2009 If it is like my 00 LS400, there may be two sensors -- a pedal position sensor and a throttle position sensor. The two work together. It is hard to tell which is defective -- the "PPS" or the "TPS". I had both the PPS and the TPS replaced on my 00 LS a few weeks ago - The TPS was $113.99 and the "PPS" was $343.72. The TPS tested as bad and the PPS tested as marginal so I had them both replaced -- total including labor and diagnosis was about $670 before tax at the indie Lexus repair shop I've used the past 12-13 years.I almost got stranded too ... I stopped driving the car until I had it fixed. Yeah, thank god I was just around the block...Thanks a lot, I appreciate it.
oooshkin Posted August 29, 2009 Posted August 29, 2009 If it is like my 00 LS400, there may be two sensors -- a pedal position sensor and a throttle position sensor. The two work together. It is hard to tell which is defective -- the "PPS" or the "TPS". I had both the PPS and the TPS replaced on my 00 LS a few weeks ago - The TPS was $113.99 and the "PPS" was $343.72. The TPS tested as bad and the PPS tested as marginal so I had them both replaced -- total including labor and diagnosis was about $670 before tax at the indie Lexus repair shop I've used the past 12-13 years.I almost got stranded too ... I stopped driving the car until I had it fixed. Where Did You get the PPS ? Do You have any reference Site so I can get it online ?
era57 Posted November 26, 2009 Author Posted November 26, 2009 If it is like my 00 LS400, there may be two sensors -- a pedal position sensor and a throttle position sensor. The two work together. It is hard to tell which is defective -- the "PPS" or the "TPS". I had both the PPS and the TPS replaced on my 00 LS a few weeks ago - The TPS was $113.99 and the "PPS" was $343.72. The TPS tested as bad and the PPS tested as marginal so I had them both replaced -- total including labor and diagnosis was about $670 before tax at the indie Lexus repair shop I've used the past 12-13 years.I almost got stranded too ... I stopped driving the car until I had it fixed. Where Did You get the PPS ? Do You have any reference Site so I can get it online ? Yeah, I got the PPS replaced. 349 for the part. Lame, but the ride is so much better now.
aj510 Posted August 29, 2010 Posted August 29, 2010 If it is like my 00 LS400, there may be two sensors -- a pedal position sensor and a throttle position sensor. The two work together. It is hard to tell which is defective -- the "PPS" or the "TPS". I had both the PPS and the TPS replaced on my 00 LS a few weeks ago - The TPS was $113.99 and the "PPS" was $343.72. The TPS tested as bad and the PPS tested as marginal so I had them both replaced -- total including labor and diagnosis was about $670 before tax at the indie Lexus repair shop I've used the past 12-13 years.I almost got stranded too ... I stopped driving the car until I had it fixed. Where Did You get the PPS ? Do You have any reference Site so I can get it online ? Yeah, I got the PPS replaced. 349 for the part. Lame, but the ride is so much better now. Hey so when your PPS was going out did you get a check engine light? I think mines going out too
1990LS400 Posted August 30, 2010 Posted August 30, 2010 Hey so when your PPS was going out did you get a check engine light? I think mines going out too I found your post after your request by PM so here is the doc you asked for that describes how to test the PPS and TPS. sf-36.pdf
aj510 Posted August 30, 2010 Posted August 30, 2010 Hey so when your PPS was going out did you get a check engine light? I think mines going out too I found your post after your request by PM so here is the doc you asked for that describes how to test the PPS and TPS. THANKS man right on ;)
junior83 Posted December 6, 2010 Posted December 6, 2010 Hey, guys. I have a '99 GS 400 and it seems that the accelerator pedal position sensor is on its way out...when I push down the gas it lurches a little until it finally reacts and at one point it totally gave out (luckily right around the block from my house), but having to drive back at 5mph sucked regardless. The car works now with the exception of the sensor being fickle soo I'm expecting it to give out eventually. Does anyone know how much this is going to cost me? I rather not have to wait until I'm stranded somewhere. :\ Any insight would be awesome. Thanks i have a 98 gs400 and been having the same problem so i went to my mechanic and got a diagnostic and got a p1120 code (accel. pedal position sensor) he called the dealer to find out how much would the job be for me and was told approx. $500. I went home and called the dealership to make an appointment i was told that it is a recall and it will be replaced free of charge. My appointment is for tomorrow so i will keep you updated on what happens to see if it the problem was fixed.
sdbt Posted February 4, 2011 Posted February 4, 2011 Hey, guys. I have a '99 GS 400 and it seems that the accelerator pedal position sensor is on its way out...when I push down the gas it lurches a little until it finally reacts and at one point it totally gave out (luckily right around the block from my house), but having to drive back at 5mph sucked regardless. The car works now with the exception of the sensor being fickle soo I'm expecting it to give out eventually. Does anyone know how much this is going to cost me? I rather not have to wait until I'm stranded somewhere. :\ Any insight would be awesome. Thanks i have a 98 gs400 and been having the same problem so i went to my mechanic and got a diagnostic and got a p1120 code (accel. pedal position sensor) he called the dealer to find out how much would the job be for me and was told approx. $500. I went home and called the dealership to make an appointment i was told that it is a recall and it will be replaced free of charge. My appointment is for tomorrow so i will keep you updated on what happens to see if it the problem was fixed.
sdbt Posted February 4, 2011 Posted February 4, 2011 I was wondering if they changed the part for free and did it fix your problem with loss of acceleration. If so what was the recall case #.
texlex430 Posted February 15, 2011 Posted February 15, 2011 I'd also like to know if they changed it for you for free. I'm experiencing the same issue.
furballi Posted June 29, 2013 Posted June 29, 2013 Anyone know of a good source for the Pedal Position and Throttle Position Sensors for a 1999 GS300 that doesn't cost a mint? I will be testing them this weekend. TIA, F
1990LS400 Posted June 29, 2013 Posted June 29, 2013 Sewell Lexus in Dallas has some of the best prices I've seen including shipping: http://lexus.sewellparts.com/accessories-catalog/Service/GS300-1999/5781.html I've bought parts from them several times and have found them to be helpful and quick. Register on the Sewell website with your forum member name to get even better prices.
furballi Posted June 30, 2013 Posted June 30, 2013 Sewell Lexus in Dallas has some of the best prices I've seen including shipping: http://lexus.sewellparts.com/accessories-catalog/Service/GS300-1999/5781.html I've bought parts from them several times and have found them to be helpful and quick. Register on the Sewell website with your forum member name to get even better prices. Thanks for the tip. I checked the throttle control motor, throttle position sensor, and pedal position sensor of the 1999 GS300 per your *pdf link in this thread. Only the pedal position sensor was out of spec...min of 1640 ohm vs. 1532 ohm actual. I have yet to calibrate the throttle position sensor because I don't know the correct setting voltage for the 1999 GS300...have read it's either 0.65VDC or 0.72-0.74VDC. Perhaps someone can chime in with the correct value. The car would usually run okay as long as I gently apply the gas while keeping the engine speed to less than 2000 rpm. Fast stabbling of the accelerator pedal would often cause a loss control of the throttle plate in the throttle body (engine speed drop to idle or a few quick revs up to about 2500 rpm). Flooring the gas will allow the mechanical throttle cable to slightly open the throttle plate, allowing the car to crawl around 30 mph. I also hear a slight buzzing sound from the throttle control motor when I turn the switch to ON without starting the engine. The noise becomes louder once I get any kind of slight movement in the pedal position sensor. This tells me that the pedal position sensor is throwing out some strange signal. Does anyone know which output wires on the pedal position sensor can be connected to an oscilloscope so that I can see if this thing is operating properly during normal driving condition? I hoping I can tap into these wires at the ECU inside the car. BTW, your link was for the throttle position sensor. I can get this item at Autozone. The part that I need to secure is the pedal position sensor that is locate on the opposite side of the throttle position sensor (near the firewall).
Jcfierros18 Posted July 11, 2014 Posted July 11, 2014 Does any body know the part number for the accelerator pedal position sensor on the 2000 gs300 on Sewell? If so I need it soon please!
Jcfierros18 Posted July 11, 2014 Posted July 11, 2014 http://lexus.sewellp...GS300-2000.html I found the apps if anyone else needs it part number 22060 also called a throttle assembly with sensor!
japman25 Posted May 28, 2016 Posted May 28, 2016 How you guys doing. can someone please tell me if there is a relay or fuse for the throttle motor for a 1998 GS400
