Stainless Steel Exhaust Tips
The exhaust tips of my 91 LS400 are the factory ones. I took them out and cleaned them but still are not to my liking. I have found these ones. What do you think-are they too much for this lady? The left is the new vs old.
From the back the new ones.
From the side
and from the distance
If you like them then try Walmart-$12.96 each plus tax.
Best
Chris
The oem are tapered, the ones from Walmart aren't. To my mind they appear blunt in comparison. A bit larger with thicker walls/edges as well. Oem are more elegant, perhaps because the original design was right to begin with in almost every aspect of the car.
A few more thoughts on the psychology of design - the oval tapered shape of the oem tips have a similar effect to that of wider tires or lower suspension - makes the car look wider and lower. The round tips make the car look a bit taller. On the other hand, they are a bit larger, and I always thought the oem were slightly undersized.
