stroker Posted May 20, 2009 Share Posted May 20, 2009 I've found that when I went to add P/S fluid that the dipstick was quite gummy so I just topped off the fluid level and closed the hood.. I feel that the system needs a real good flush..Is there some kind of cleaner to flush the system or do I have to waste new ATF?? Thanks to all. B. Quote Link to comment Share on other sites More sharing options...
jcrome04 Posted May 20, 2009 Share Posted May 20, 2009 Turkey baster or pump. Pump fluid out of the reservoir, replace with same amount of new fluid, start car and turn the wheel lock to lock about 20-30 times. Repeat until the fluid coming out is nice and red. this would be the easiest way to flush it all out. When I did this I used Mobil1 Synthetic fluid. Quote Link to comment Share on other sites More sharing options...
stroker Posted May 21, 2009 Author Share Posted May 21, 2009 Turkey baster or pump.Pump fluid out of the reservoir, replace with same amount of new fluid, start car and turn the wheel lock to lock about 20-30 times. Repeat until the fluid coming out is nice and red. this would be the easiest way to flush it all out. When I did this I used Mobil1 Synthetic fluid. thanks for your reply..Did you use mobil 1 synthetic brake fluid or tranny fluid? My book says tranny fluid.. Thanks again, Bob Quote Link to comment Share on other sites More sharing options...
AzHotLS Posted May 21, 2009 Share Posted May 21, 2009 Don't suck it out!! Unscrew the solenoid at the rack and let drain out. While you're at it, clean the solenoid screen. Kill two birds with one stone!The solenoid screen should be cleaned every couple years to minimize the problems the OP mentions. http://www.clublexus.com/forums/ls400-foru...freshen-up.html While it is good to remove the solenoid to clean the screen letting the fluid drain, it would be good to do a proper flush (with ATF) by removing the return hose at the reservoir having the fluid drain into a gallon milk bottle while pouring new ATF into the reservoir. The pictures are gone, but here is an excellent thread explaining the procedure: http://us.lexusownersclub.com/forums/index...?showtopic=6351 Quote Link to comment Share on other sites More sharing options...
jcrome04 Posted May 21, 2009 Share Posted May 21, 2009 Yes, tranny fluid. Quote Link to comment Share on other sites More sharing options...
yank30265 Posted January 7, 2010 Share Posted January 7, 2010 Yes, tranny fluid. would that be mercon V? dex merc?....which atf? Quote Link to comment Share on other sites More sharing options...
ggemigniani Posted January 8, 2010 Share Posted January 8, 2010 Dexron III automatic transmission fluid Quote Link to comment Share on other sites More sharing options...
