camlex Posted May 19, 2009 Posted May 19, 2009 Hello, Please review attached picture. There is one drain plug for differential fluid. then one fill plug and at same level two other plug. Questions: 1. What reason 2. Can you use one out of those two plug for fill differential fluid (Same as trans. DEX-III) Easy to put tube from top (99 and UP model has differential drain plug but fill from top through dip stick) correct me if i am wrong. Thanks,
George_Jetson Posted May 19, 2009 Posted May 19, 2009 Weird that they have three plugs there, the one looks a little higher than the other two. I looked it up in my manual, but there is no explaination.
camlex Posted May 19, 2009 Author Posted May 19, 2009 Thanks george, Top one is easy to open from top and has room to work, should i use that to fill, capacity for Diff. fluid is 0.9 qt. may be 1/2" above fill plug. Thanks,
camlex Posted May 21, 2009 Author Posted May 21, 2009 I opened top bolt (12mm). I can see transmission fluid. i lost 10-12 drop. its telling me that fill plug and top bolts at the same level. George, i am thinking these are for may be bleed purpose. How many miles you should change differential fluid? Thanks,
George_Jetson Posted May 21, 2009 Posted May 21, 2009 Not sure, I don't see that on the service interval. I would probably do it at the same time I serviced the trans.
camlex Posted May 27, 2009 Author Posted May 27, 2009 It's Done @ 353,900. next one I will do @400K. Thanks,
realweb Posted December 27, 2010 Posted December 27, 2010 It's Done @ 353,900. next one I will do @400K. Thanks, So, which once was the Fill hole? and do you happen to remember the sizes and type for fill and drain?. (socket/allen) Thanks
