97 Differential Fluid
Hello,
Please review attached picture. There is one drain plug for differential fluid. then one fill plug and at same level two other plug.
Questions:
1. What reason
2. Can you use one out of those two plug for fill differential fluid (Same as trans. DEX-III) Easy to put tube from top
(99 and UP model has differential drain plug but fill from top through dip stick) correct me if i am wrong.
Thanks,
I opened top bolt (12mm). I can see transmission fluid. i lost 10-12 drop. its telling me that fill plug and top bolts at the same level.
George, i am thinking these are for may be bleed purpose.
How many miles you should change differential fluid?
Thanks,
  • 1 year later...
