pearlwhite97ES Posted May 1, 2009 Share Posted May 1, 2009 What would be symptoms of a belt that slipped or one thats going out? My problem is the car feels like it's running on 5 cylinders and is really shakey...It has rained here alot lately and i also wondered if something got wet..any ideas or help is appreciated thanks Quote Link to comment Share on other sites More sharing options...
George_Jetson Posted May 1, 2009 Share Posted May 1, 2009 If it slipped a tooth, there would be very little power. How long has it been since your last tuneup? If it has been a long time, that is where I would start. Make sure that you check the plug wires. Quote Link to comment Share on other sites More sharing options...
pearlwhite97ES Posted May 2, 2009 Author Share Posted May 2, 2009 If it slipped a tooth, there would be very little power. How long has it been since your last tuneup? If it has been a long time, that is where I would start. Make sure that you check the plug wires. I changed the plugs and plug wires and it runs like a top again..... should I change the fuel filter? I got this car from a little ole lady with 75k miles and now it has 85k I don't think she ever did any maintence past 30k.. So far I've change the oil 4 times in 10k miles,had the tranny flushed,anti freeze flushed, plugs and wires changed last night "very tough job"....Timing belt,seals,and water pump soon. Quote Link to comment Share on other sites More sharing options...
George_Jetson Posted May 2, 2009 Share Posted May 2, 2009 I would change out the fuel filter, catch up on all the maint so that you know exactly where you stand. Quote Link to comment Share on other sites More sharing options...
