Fs: Oem Lexus Both Rear Caliper Rebuild Kit 98-00 Ls400 $40 Shipp
I know it works for 98-00 and should also be 95-97 .
I have an extra set of rear caliper rebuild kits.
i thought i needed more when i placed my order for all 4 corners.
It is basically
the outer piston dust boots
the snap ring to hold the dust boot
the inner piston fluid seal
pink seal grease
a new bleeder dust boots
new slider dust boots
new brake line gaskets
X2 for all above
This kit is all wear items for both rear calipers. I did mine this weekend in a few hours and the pedal is much more responsive after i made a few hard stops to brake in the pads again as the surfaces are mating properly now.
The only thing to make it perfect is a new set of sliders.
If interested let me know.
